Use the rule-redirect command to enable or disable policy rule-based redirection. The rule-redirect command is accessible from within the root: vnsmode:adminctr context.
| enable | Enables policy rule-based redirection for ExtremeWireless versions prior to v10.11. Policy rule-based redirection is enabled for ExtremeWireless v10.11 by default. For installations coming from an upgrade, enable rule-redirect. |
| disable | Disables policy rule-based redirection. Policy rule-based redirection is enabled for ExtremeWireless v10.11 by default. |
Enable rule-redirect from the adminctr context before issuing other redirection commands. When this command is enabled, the redirection URL list is available from the VNS screen. For ExtremeWireless v10.11 and later, rule-based redirection is enabled by default. Enable rule-based redirection in ExtremeWireless release versions prior to v10.11 using the rule-redirect command.
EWC.extremenetworks.com:vnsmode:adminctr# rule-redirect enable
EWC.extremenetworks.com :vnsmode:adminctr# apply
Exit adminctr and refresh vnsmode before issuing the redirection url commands.
Print
this page
Email this topic
Feedback
