Use the hs-provider-desc1 command from the provider-config context to configure the OSU provider description.
| description | Specify the OSU provider first description. |
EWC.extremenetworks.com:wlans:hs:hotspot# provider-config https://Enetworks.com
EWC.extremenetworks.com:wlans:hs:hotspot# hs-provider-desc1 "First description"
Print
this page
Email this topic
Feedback
