Use the dns command to specify the IP addresses for one or more DNS servers. The dns command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies. This command is visible only when mode is set to local. See mode.
After you run the dns command, run the apply command to implement the changes.
| DNS server | Specifies the IP address of a DNS server. |
| none | Clears the DNS server. |
The following example specifies the IP addresses of two DNS servers:
EWC.extremenetworks.com:topology:test:l3:dhcp# mode local EWC.extremenetworks.com:topology:test:l3:dhcp# dns 192.168.1.2, 192.168.1.3 EWC.extremenetworks.com:topology:test:l3:dhcp# apply
Print
this page
Email this topic
Feedback
