Use the server command to select a RADIUS server. The server command is available from the login:auth context.
| # | Specifies the index number of the RADIUS server to be used |
| name | Specifies the name of the RADIUS server to be used |
The following example selects a radius server by name:
EWC.extremenetworks.com:login:auth# server rad2
Print
this page
Email this topic
Feedback
