mac-format-1x
Use this
command to override the default MAC address colon-separated format (for example
00:11:22:33:44:55) with the Global Authentication MAC Address Format (for Mac Based
Authentication) for the following attributes:
- Calling-Station-Id attribute of the RADIUS packet
- Called-Station-Id attribute (if Called-Station-Id is not overridden by Zone name)
- AP BSSID Mac in one of the vendor attributes
- User-Name attribute (Mac Based Authentication)
This command is available from the vnsmode:radius context. It is enabled for new
deployments. You must manually enable this setting for upgraded deployments.
mac-format-1x
(enable|disable)
Parameters
| enable |
Use MAC-Based Authentication MAC address format for user
authentication and accounting via RADIUS |
| disable |
Disable mac-format and use MAC address colon-separated
format. |
This example sets the
authentication to MAC-Based Authentication MAC address format for user authentication and
accounting via RADIUS.
EWC.extremenetworks.com:vnsmode:radius# mac-format-1x enable
