Use the move command to change the order of this authentication server on this site. The move command is accessible from the site:<named-site> context.
| 1-32 | Specifies a value in an ordered list of servers for this authentication server on this site. Enter the first (current) position of the server, then the new position of the server in the server order. |
The CLI <named-site> context must be in config mode for a RADIUS server, to execute the move command. Use the config radius name command to enter config mode. Use config exit to exit config mode.
You must enter the apply command before exiting the site:<named-site> context for the site name change to take affect. The CLI prompt does not change until you exit and re-enter the site:<named-site> context.
The following example moves the authentication server from position 1 to 2 in the order:
EWC.extremenetworks.com:site:site1# move 1 2
Print
this page
Email this topic
Feedback
