show
Use the show command to display the configuration for capturing the exception traffic to and from the management plane.The show command is accessible from the traffic_capture context of the CLI.
show
Parameters
None
The following example displays the configuration for capturing the exception traffic to and from the management plane:
EWC.extremenetworks.com:traffic_capture# show
Interface: esa2
Filename: mgmt_traffic_dump.cap
Destination: local
Capture Status: stopped
Traffic Capture Files:
    1:mgmt_traffic_dump.cap
