Use the max-voice-reassoc command to set the maximum allowed overall bandwidth on the new AP when a client with an active voice stream roams to a new AP and requests admission for the voice stream.
After you run the max-voice-reassoc command, run the apply command to implement the changes.
| 0-100 | Specifies the maximum allowable bandwidth as a percentage of total bandwidth. |
The following example sets the maximum voice bandwidth for roaming streams to 80%:
EWC.extremenetworks.com:vnsmode:adminctr# max-voice-reassoc 80
Print
this page
Email this topic
Feedback
