Use the hs-ofn-venue command from the hotspot context to configure the hotspot venue identification.
| (add|update|delete) | Add, update, or delete a venue. Specify a language, operator name, and venue name. |
| operator | Operator name. If using spaces in <operator> string, surround the string with double quotes. |
| lang | Language code. See Language Codes. |
| venue | Venue name. If using spaces in <venue> string, surround the string with double quotes. |
EWC.extremenetworks.com:wlans:hs:hotspot# hs-ofn-venue add tha JohnDoe CityCenter
Print
this page
Email this topic
Feedback
