wlanUse the wlan command to assign or unassign one or both of the AP‘s radios to the specified WLAN service. The wlan command is accessible from the ap:<serial> context of the CLI.
When configuring the AP3912, you can assign one or more client ports to a single WLAN service, but the port can only be assigned to one service. Wired ports can only be assigned to open WLAN services. There is no security or privacy on the client ports.
| wlans name | The service you want the AP's radios to be assigned to or removed from. |
| radio1 | radio2 | both | Specifies the radios to assign to the WLAN service. Use both to assign both radios at one time. |
| no-radio1 | no-radio2 | none | Specifies the radios to unassign to the WLAN service. Use none to remove all assignments at one time. |
| p1 | p2 | p3 | Specifies the client ports on the AP3912 to assign to the WLAN service. |
| no-p1 | no-p2 | no-p3 | Specifies the client ports on the AP3912 to unassign to the WLAN service. |
EWC.extremenetworks.com:ap:0500008043050355# wlan CNL-91-0-1 radio2 EWC.extremenetworks.com:ap:0500008043050355# show host_name AP3935-0500008043050355 name AP3935 internal desc usedhcp poll_timeout 15 client_session no persistent no bcast_disassoc no vlanid country Germany led-mode normal wlan CNL-91-0-1 radio2
EWC.extremenetworks.com:ap:0500008043050355# wlan CNL-91-0-1 radio2 p3
