Use the access command to modify the registration status of Wireless APs on the system. The access command is accessible from the ap context of the CLI.
If rehoming is enabled, the command to change a local AP to a Foreign AP is:
access ap_serial foreignThe command to change a foreign AP to a Local AP is:
access ap_serial approved| ap_serial | The serial number of the Wireless AP. |
| release | pending | approved | reboot | foreign | The administrative options for the Wireless AP. |
Rehoming is enabled if availability is enabled between two V9.01 and higher controllers. Both Controllers need to be in the same regulatory domain. APs in WDS/MESH configurations cannot be rehomed. APs in load groups will be removed from the load group if they are rehomed.
The following example modifies the status of a Wireless AP to pending:
EWC.extremenetworks.com:ap# access 0409920201204003 pending
The following example reboots the Wireless AP:
EWC.extremenetworks.com:ap# access 0500008043050355 reboot Rebooting selected AP may result in a localized service interruption. Are you sure you want to continue(yes/no)? (yes/no):yes
Print
this page
Email this topic
Feedback
