Use the show command to display the current authentication settings of the specified individual WLAN service. The show command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
The following example displays the current authentication settings for the WLAN service named Lab126-12-AAA:
EWC.extremenetworks.com:wlans:Lab126-12-AAA:auth# show No radius server has been selected Priority Name Role NAS IP NAS ID Auth Type 1 IAS auth Use VNS IP address Use VNS name EAP 1 IAS acct Use VNS IP address Use VNS name MAC-based authorization: disable Authentication mode: 8021x AP as VSA attribute: enable SSID as VSA attribute: enable VNS as VSA attribute: enable Policy as VSA attribute: enable Topology as VSA attribute: enable Ingress rate control as VSA attribute: enable Egress rate control as VSA attribute: enable Interim interval (minutes): 0 Collecting accounting information of Wireless Controller: disable With external: disable
Print
this page
Email this topic
Feedback
