The <named-role> command, where <named-role> refers to the name of a given role, provides access to the role:<named-role> context.
The role:<named-role> context provides commands for the configuration of the <named-role>. A <named-role> must first be created using the create command in the role context. Once created it becomes available as a command, allowing access to the role: <named-role> context for that role. For example, to enter the <named-role> context for the role named p6, use the command p6 from the role context, created using the create p6 command.
After you complete configuration changes for a <named-role>, run the apply command before exiting the role:<named-role> context to implement the changes.
The following commands are available in the role:<named-role> context.
Print
                        this page
Email this topic
Feedback
