Use the learnac command to allow the Wireless AP to provide its own EWC Search List. Use no form of the command to disable this feature. The learnac command is accessible from the ap:defaults context of the CLI.
If you disallow the Wireless AP from providing its own EWC Search List, you should specify the controller's static IP address by running the aclist command. For more information, see aclist. If you disallow the Wireless AP from providing its own EWC Search List and do not specify the controller's static IP address, the Wireless AP uses the SLP to discover the controller.
After you run the learnac command, run the apply command to implement the changes.
None
The following example allows each Wireless AP to provide its own EWC Search List:
EWC.extremenetworks.com:ap:defaults# learnac
Print
this page
Email this topic
Feedback
