Use the size command to specify the file size of TCPDump file. The size command is accessible from the traffic_capture context of the CLI.
Refer to the Wireless Appliance Convergence Software Maintenance Guide for more information.
| filesize | Specifies the file size of TCPDump file. File size can range from 10 MB (minimum) to a maximum of 1 GB. |
The following example specifies the file size of the TCPDump file as 15MB:
EWC.extremenetworks.com:traffic_capture# size 15
Print
                        this page
Email this topic
Feedback
