Use the trap-manager-v1v2 command to identify either the primary or secondary machine monitoring SNMPv1/v2 traps by IP address.
| 1|2 | Identifies the primary or secondary machine monitoring SNMPv1/v2 traps |
| IP Address | Specifies the IP address of the machine monitoring SNMPv1/v2 traps. The IP address can be either IPv4 (A.B.C.D) or IPv6 (A:B:C:D:E:F:G:H) format. |
| delete | Delete the specified trap manager. |
The following example specifies the IP address of the primary machine monitoring SNMPv1/v2 traps:
EWC.extremenetworks.com:snmp# trap-manager-v1v2 1 192.168.1.5
The following example deletes the secondary machine monitoring SNMPv1/v2 traps:
EWC.extremenetworks.com:snmp# trap-manager-v1v2 2 delete
Print
                        this page
Email this topic
Feedback
