Use the redirection-url command to configure a redirection URL from the command line. The redirection-url command is accessible from within the role: <named-role> context.
| id | An index number that identifies the redirection URL in the database. |
| redirection url | Identifies the redirection URL |
You can specify a redirection URL by its sequence ID or by the actual URL. To display the list of possible redirection URLs associated with the role, type redirection-url.
Available Redirection URL: 0 Own WLAN 1 http://2.2.2.2 2 http://3.3.3.138 3 http://3.3.3.140 4 (ffecp) http://192.168.11.22:/logincode_m-f.php?hwc=10.12.0.1
When External Captive Portal URLs exist, they are automatically added to the list.
The following example specifies the redirection-url by sequence ID.
EWC.extremenetworks.com:role:role1#: redirection-url 1
Print
this page
Email this topic
Feedback
