Use the topology-name command to associate an already existing topology with a role. The topology-name command is accessible from the vnsmode:default-role context.
| topology | Specifies the name of the topology to configure for this vnsmode:default-role context. |
Refer to VNS Commands (vnsmode) for information on configuring topologies.
The following example configures the default-role with the guestPortal topology:
EWC.extremenetworks.com:vnsmode:default-role# topology-name guestPortal EWC.extremenetworks.com:vnsmode:default-role# apply EWC.extremenetworks.com:vnsmode:default-role# show Assigned topology: guestPortal Ingress rate profile: Unlimited Egress rate profile: Unlimited Enable AP filtering: disable Synchronize: enable EWC.extremenetworks.com:vnsmode:default-role#
Print
this page
Email this topic
Feedback
