Use the push-list command to configure a push URL list. This command is available from the location:publish context.
push-list (add <[userid userid-string password password-string url url]*>|delete <[url|sequenceId]*>)
| add | delete | Specifies whether the URL is being added or deleted from the push list. |
| userid userid-string | Specifies a user ID. |
| passwordpassword-string | Specifies a password. |
| url [url]* | Specifies one or more URLs, delineated by a space, to add to the location push list. |
| sequenceId | ID of the URL. You can delete the URL by the sequence ID. |
The following example adds the www.myurl.com URL to the push list:
EWC.extremenetworks.com:location:publish# push-list add userid UserID1 password qwerty12345 url https://www.myurl.com
The following example adds a URL with a blank User ID and password:
EWC.extremenetworks.com:location:publish# push-list add userid "" password "" url http://www.test.com/test
The following example shows the URLs in the push list:
EWC.extremenetworks.comlocation:publish# show SequenceId Userid Password url 1 1 * http://1.1.1.1 2 2 *************** http://1.1.1.2 3 3 *********** http://1.1.1.121
The following example deletes the second URL by sequence ID:
EWC.extremenetworks.com:location:publish# push-list delete 2.
