Use the ssid-suppress command to allow or prevent the SSID from being broadcast by the Wireless AP. The ssid-suppress command is accessible from the wlan:<WLAN-service-name>:rf context of the CLI.
After you run the ssid-suppress command, run the apply command to implement the changes.
| enable | disable | Enables or disables the suppression of broadcast of the SSID. |
The following example prevents SSID broadcasts:
EWC.extremenetworks.com:wlans:CNL6-AAA# ssid-suppress enable EWC.extremenetworks.com:wlans:CNL6-AAA# apply
Print
this page
Email this topic
Feedback
