This section describes commands to enable and disable ports on the Wireless Appliance. These commands are located in the l2ports context of the CLI. L2 port configuration is performed within a named topology context. See l2 for L2 port configuration information.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the l2ports context:
Print
                        this page
Email this topic
Feedback
