Use the custom command to enable or disable VNS customization (overwriting of defaults) by the RADIUS server.
The custom command is accessible from the site:<named-site> context.
| enable | disable | Enables or disables VNS customization (overwriting of defaults) by the server. |
The CLI <named-site> context must be in config mode for a RADIUS server to execute the custom command. Use the config radius name command to enter config mode. Use config exit to exit config mode.
The following example enables VNS customization by the RADIUS server:
EWC.extremenetworks.com:site:site1# custom enable
Print
this page
Email this topic
Feedback
