Use the hs-natype command from the hotspot context to configure the Network Authentication Type for the hotspot.
| HttpHttpsRedirection | Redirect Http or Https automatically. |
| OnlineEnrollmentSupported | Authentication supports online enrollment. |
| AcceptanceOfTermsAndConditions | Redirection is accomplished after user accepts Terms and Conditions. |
| DNSRedirection | DNS redirection serves a web page other than what the end user had requested. |
Before you can use hs-natype, create a hotspot enabled WLANS.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-na-type HttpHttpsRedirection
Print
this page
Email this topic
Feedback
