secmode
Use the secmode command to set the Security Mode to allow only approved Agents to connect to the manager, or allow all agents to connect.
secmode (approved|none)
Parameters
approved Allows only approved agents to connect to the manager
none Allows all agents to connect to the manager
The following example configures the security mode to have no restrictions, allowing all agents to connect to the manager:
EWC.extremenetworks.com:mobility# secmode none
