Use the vsa-ssid command to include SSID information in the message to the RADIUS server. The vsa-ssid command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the vsa-ssid command, run the apply command to implement the changes.
| enable | disable | Specifies to enable or disable the inclusion of SSID information in messages to the RADIUS server. |
The vsa-ssid command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of SSID information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-ssid enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-ssid SSID as VSA attribute: enable
Print
this page
Email this topic
Feedback
