Use the priority-override-up command to override existing Service Class settings for priority processing and configure a single Service Class value for the WLANS. The priority-override-up command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the priority-override-up command, run the apply command to implement the changes.
| 0-7 | Specifies a Service Class value. Default value: 1. |
This command is only active if the priority-override command has been enabled. For more information, see priority-override.
The following example overrides all existing Service Class settings and configures a single Service Class of 4 for the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos_policy# priority-override-up 4 EWC.extremenetworks.com:wlans:CNL-7-CP:qos_policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos_policy# show priority-override-up Service class: 4
Print
this page
Email this topic
Feedback
