Use the cp-ssl command to enable or disable HTTPS support on a WLAN service configured for external authentication. The cp-ssl command is available only if mode is set to external. For more information about the mode command, see mode.
| enable | Enable HTTPS support on the WLAN service configured for external authentication. |
| disable | Disable HTTPS support on the WLAN service configured for external authentication. |
By default, HTTPS support is disabled.
The following example enables HTTPS support on the WLAN service:
EWC.extremenetworks.com:wlans:external_wlan:auth:captiveportal# cp-ssl enable EWC.extremenetworks.com:wlans:external_wlan:auth:captiveportal# apply
Print
this page
Email this topic
Feedback
