Use the hs-dgaf command from the hotspot context to configure hotspot downstream group-addressed forwarding.
| (enable|disable) | Enable or disable Downstream Group-Address Forwarding. This option is disabled by default. When DGAF is disabled, the AP is not forwarding downstream group-addressed frames. |
EWC.extremenetworks.com:wlans:hs:hotspot# hs-dgaf enable
Print
                        this page
Email this topic
Feedback
