Use the mac command to enable or disable MAC based authentication. The mac command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
| enable | disable | Specifies to enable or disable MAC based authentication |
The mac command is not available in the guest splash and guest portal authentication modes. For more information, see mode.
The following example enables MAC authentication for the test WLANS:
EWC.extremenetworks.com:wlans:test:auth# mac enable EWC.extremenetworks.com:wlans:test:auth# show mac MAC based authorization: enable
Print
                        this page
Email this topic
Feedback
