Use the auth command to assign a default role for authenticated clients. This command is available from the vnsmode:<named-VNS> context.
After you run the auth command, run the apply command to implement the changes.
| non-auth | Use the default role for non-authenticated clients for authenticated clients. |
| role-name | Specifies the name of the role to use as the default role for authenticated clients. |
When you assign a default authenticated role to this VNS, the same rules apply as when a VNS is created. That is — if the VNS‘s WLAN Service has a mode of:
The following example specifies that the role named “auth-users” should be used as the default role for authenticated users for the VNS named VNS1:
EWC.extremenetworks.com:vnsmode:VNS1# auth auth-users
This example specifies that the same role used as the default role for non-authenticated users should be used for authenticated users for the VNS named VNS1:
EWC.extremenetworks.com:vnsmode:VNS1# auth non-auth EWC.extremenetworks.com:vnsmode:VNS1# apply
Print
this page
Email this topic
Feedback
