Use the security-scan command to enable or disable security scans. The security-scan command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the security-scan command, run the apply command to implement the change.
| enable | Enables security scans for rogue APs. |
| disable | Disables security scans for rogue APs. |
The following example enables security scans:
EWC.extremenetworks.com:mitigator:scprof:scp_name# security-scan enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
this page
Email this topic
Feedback
