aplistUse the aplist command to add or remove an AP to or from the WLAN service configuration. The aplist command is accessible from the wlan:<WLAN-service-name> context of the CLI when the WLAN service type is standard.
After you run the aplist command, run the apply command to implement the changes.
When configuring the AP3912, you can assign one or more client ports to a single WLAN service, but the port can only be assigned to one service. Wired ports can only be assigned to open WLAN services. There is no security or privacy on the client ports.
| ap-name | Specifies the name of the AP to add or remove from the WLAN service. The no form of the command removes the AP |
| radio1 | radio2 | both | Specifies to use radio1, radio2, or both with the WLAN service |
| Supported on the AP3912: | |
| p1 | p2 | p3 | Specifies which port to configure for the WLAN service. |
The following example adds an AP3912i by AP name to the WLAN service named “test” and then displays the list of Wireless APs with port assignments:
EWC.extremenetworks.com:wlans:test# aplist AP3912i_1637Y-1003100000 p1 p3 EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show aplist
