Use this command to enable or disable inter-WLAN roaming on this WLAN service. The interwlan-roaming command is accessible from the wlan:<WLAN-service-name> context of the CLI.
| enable | Enables the inter-WLAN roaming feature for this WLAN service. This is the default setting. |
| disable | Disables the inter-WLAN roaming feature. |
This example disables inter-WLAN roaming on the WLAN service named test:
EWC.extremenetworks.com:test# interwlan-roaming disable
Print
this page
Email this topic
Feedback
