Use the defer-acct-start command to enable or disable defering sending the accounting start request until the client's IP address is known. The defer-acct-start command is accessible from the vnsmode:radius context of the CLI.
The global setting of Radius Accounting must be enabled prior to using this command. Defer accounting start is disabled by default.
| enable | Enables the defer accounting start feature. |
| disable | Disables the defer accounting start feature. |
The following example enables defer accounting start:
EWC.extremenetworks.com:vnsmode:radius# defer-acct-start enable
Print
this page
Email this topic
Feedback
