Use this command to configure the maximum number of clients for each radio when the radio load control feature is enabled. The radio-load command is accessible from the ap:load-groups:<named-load-group> context of the CLI, for the radio type of load group.
| radio1 | radio2 | Specifies the radio being configured. |
| max-clients | Specifies the maximum number of clients for the specified radio. Can be an integer between 5 and 60. |
For access to this command, the radioN-loadcontrol command must be enabled.
This example enables load control per radio for load group named radiogroup1, then specifies the maximum number of clients for radio 1 and radio 2:
EWC.extremenetworks.com:ap:load-groups:radiogroup1# loadcontrol enable EWC.extremenetworks.com:ap:load-groups:radiogroup1# radio-load radio1 40 EWC.extremenetworks.com:ap:load-groups:radiogroup1# radio-load radio2 50
Print
this page
Email this topic
Feedback
