Use the file_name command to specify a file name for the TCPDump. If you do not assign any file name to the TCPDump, the CLI gives a default name mgmt_traffic_dump.cap. The CLI enforces .cap file extension to the TCPDump file. The file_name command is accessible from the traffic_capture context of the CLI.
| fileName | Specifies the file name for the TCPDump |
The following example specifies the file name as TrafficCapture for the TCPDump:
EWC.extremenetworks.com:traffic_capture# file_name TrafficCapture
Print
this page
Email this topic
Feedback
