Use the filter-status command to enable or disable a checkbox, which allows you to inherit filter rules from currently applied role. Selecting the Inherit filter rules from currently applied role checkbox overwrites any pre-existing filter settings. If the checkbox is not selected, the wireless client uses filter settings from a previously applied role. If filters have not been defined, the system enforces filters from the Global Default Role.
| enable | The Inherit filter rules from currently applied role checkbox is available in the wireless client. |
| disable | The Inherit filter rules from currently applied role checkbox is not available in the wireless client. |
The following example enables the Inherit filter rules from currently applied role checkbox in the wireless client:
EWC.extremenetworks.com# filter-status enable
The following example disables the Inherit filter rules from currently applied role checkbox in the wireless client:
EWC.extremenetworks.com# filter-status disable
Print
this page
Email this topic
Feedback
