Use this command to enable or disable the ability to change RADIUS server settings per WLAN Service. This command is available from the vnsmode:radius context.
| enable | Enables changing RADIUS server settings per WLAN Service. |
| disable | Disables changing RADIUS server settings per WLAN Service. |
This example disables changing RADIUS server settings per WLAN Service:
EWC.extremenetworks.com:vnsmode:radius# strict disable
Print
this page
Email this topic
Feedback
