Use the aplist-wds command to add or remove an AP to or from a WDS type WLAN service configuration. The aplist-wds command is accessible from the wlans:<WLAN-service-name> context of the CLI when the WLAN service type is WDS.
aplist-wds (Mesh) for information about using the command to configure a dynamic mesh WLAN service.
Use this command to configure the following:
After you run the aplist-wds command, run the apply command to implement the changes.
| radio1 none | child | parent | both | Specifies the AP‘s role on Radio1 |
| radio2 none | child | parent | both | Specifies the AP‘s role on Radio2 |
| both none | child | parent | both | Specifies the AP‘s role on both radios |
| pref-parent ap-name | Any Parent | Specifies the AP‘s parent |
| backup-parent ap-name | Any Parent | Specifies the AP‘s backup parent |
| wkgbridge off | on | Configures the work group bridging |
This command is only available when the WLAN service type is WDS.
The following example reflects the following:
EWC.extremenetworks.com:wlans:shopfloor_WDS_wlan# aplist-wds Lancaster radio1 child radio2 parent pref-parent Aruba backup-parent Auberon wkgbridge off EWC.extremenetworks.com:wlans:shopfloor_WDS_wlan# apply
