CLI Wizard
        The CLI wizard is designed to configure
            administrative settings on the controller. The CLI wizard begins automatically when a
            user with administrative access logs into the controller for the first time or when the
            system has been reset to the factory default. Instructions display when the wizard
            starts. Each screen in the wizard presents the default response in square brackets [ ].
            Simply press
Enter to accept
            the default response. You can exit the wizard by pressing
CTRL +
C.
Take the following steps to configure the controller through the CLI
            wizard:
                Press Enter to begin.
                Change the admin password on the account?
                Change AP access password?
                     Note    For the initial configuration, you must change the factory default AP
                        password.
                Change port Physical 1 settings?
                    - Press Enter to
                        change settings on port Physical 1, or
- Type n and press
                            Enter to
                        accept all default settings.When modifying Physical 1
                            port settings:
                                - Type an IP address and press Enter or
                                    press Enter to accept the default IP address
                                    value.
- Type a netmask value and press Enter or
                                    press Enter to accept the default netmask value.
- Type a VLAN ID and press Enter or
                                    press Enter to accept the default VLAN ID value.
                Will the interface transmit tagged frames?
                    - Press Enter for No, or
- Type y and press
                            Enter for
                        Yes.
                Would you like to enable management?
                    - Press Enter for Yes, or
- Type n and press
                            Enter for
                        No.
                Would you like to enable AP registration?
- Type n and press
                            Enter for
                        No.
 A summary of configured Data
                    Plane Settings is displayed. Press Enter to accept the settings or type n
                    and press Enter to
                    reconfigure the Data Plane Settings.
                Would you like to change the host attributes?
- Type n and press
                            Enter for
                        No.
                    When modifying host attributes:
                        - Type the host name for the appliance and press
                                Enter, or
                            press Enter to
                            accept EWC.
- Type the IP address for the Admin Port and press
                                Enter, or
                            press Enter to
                            accept the default IP address value.
- Type the IP netmask for the Admin Port and press
                                Enter, or
                            press Enter to
                Do you want to have a name server? (Primary DNS)
                    - Press Enter for Yes, and enter
                        an IP address for the name server, or
- Type n and press
                            Enter for No.
                        Go to step 11.
                Do you want to have a secondary name server? (Secondary DNS)
- Type y and press
                            Enter for Yes.
                        Then, enter an IP address for the name server.
                Enter the domain name for the appliance.
                    - Press Enter to accept the
                        default domain name for the appliance.
- Enter a unique domain name and press
                        enter.
                Would you like to configure a global default gateway?
                    - Press Enter to configure a
                        global default gateway, and enter the global default gateway IP address,
                        or
- Type n and press
                            Enter for
                        No.
 A summary of host attribute
                    settings is displayed. Press Enter to accept the settings, or type n
                    and press enter to reconfigure the host attribute settings.
                Would you like to enable SNMP?
- Type n and press
                            Enter for
                        No.
                    When enabling SNMP:
                        - Type the SNMP3 account user name and press
                                Enter, or
                            press Enter to
                            accept the default user name.
- Type the authentication password (8-32 characters) and press Enter, or press
                                Enter to
                            accept the default authentication password.
- Enter a privacy password (8-32 characters) and press Enter, or press
                                Enter to
                            accept the default privacy password.
 A summary of SNMP settings is
                    to accept the settings or type n and press Enter to reconfigure the SNMP
                    settings.
                Change time settings?
                    - Press Enter to change time
                        settings, or
- Type n and press
                            Enter to
                        accept default time settings.
                        Change time zone?
                                - Press Enter to
                                    change time zone, or
- Type n and press
                                        Enter to accept default settings.
                            To change the
                                    time zone, select a value from the list of continents. Then,
                                    select a value from the list of regions.  Note    The  ExtremeWireless graphical user interface (GUI) offers
                                valid time zone options that you can select from drop list fields.
                                For more information, see the Wireless
                                    User Guide.
                        Change time?
                                    or
- Type y and press
                                        Enter for Yes. Then, enter a date and time in
                                    format (mm-dd-yyyy hh:mm) and press Enter. The
                                    time is in 24-hour format.
                        Run NTP as a client?
                        Enter a second NTP server?
                                - Press Enter for
                                    No.
- Type y and press
                                        Enter for Yes.
 If entering a second NTP server, enter the fully
                                qualified domain name or IP address of the NTP
                                server. You can configure up to three NTP servers.
                        Make this controller an NTP server?
                                - Press Enter for
                                    No.
- Type y and press
                                        Enter for Yes.
 A summary of Time Settings is
                    to accept the settings or type n and press Enter to reconfigure the Time
                    Settings.
                The Controller Post Configuration options appear.
                    Review the full configuration. To return to a portion of the configuration
                    wizard, enter the number that corresponds to that portion of the configuration
                    wizard. To save and exit, press Enter.
                     Note    If you exit the wizard without saving changes, the
                        wizard will run the next time you access the controller.
                    - 1 - Return to the Change
                        Admin Password screen from which you can change the administrator's
                        password.
- 2 - Return to the Change
                        AP Password screen from which you can change the AP access
                        password.
- 3 - Return to the Data
                        Plane Settings screen from which you can change the settings for physical
                        ports on the controller.
- 4 - Return to the Host
                        Attribute Settings screen from which you can change the host attributes for
                        the controller.
- 5 - Return to the Current
                        SNMP Settings screen from which you can change the SNMP settings for the
                        controller.
- 6 - Return to the Time
                        Settings screen from which you can change the date and time settings and
                        configure NTP servers.
- 7 - Save your changes and
                        exit the wizard.
- 8 - Exit the wizard
                        without saving your changes.
 The wizard is complete. This guide
                    provides information about individual commands available in the CLI.  For
                    additional information about configuration and setup information for both the
                    wireless controller and APs, refer to the Wireless
                        User Guide.
