mac-allow-unauthorized
Use the mac-allow-unauthorized command to allow the authentication of unauthorized users. The mac-allow-unauthorized command is accessible from the wlans:<WLAN-service-name>:auth context of the CLI.
After you run the mac-allow-unauthorized command, run the apply command to implement the changes.
mac-allow-unauthorized enable | disable
Parameters
enable | disable Specify to enable or disable the authentication of unauthorized users on this WLANS service
Usage
The mac-allow-unauthorized command is available in all authentication modes, if MAC authentication is enabled, using the mac enable command. For authentication mode command information, see mode. For mac command information, see mac.
The following example enables the authentication of unauthorized users for the cnl-mac WLANS service:
EWC.extremenetworks.com:wlans:cnl-mac:auth# mac-allow-unauthorized enable
EWC.extremenetworks.com:wlans:cnl-mac:auth# apply
