Use the egress-filtering command to enable or disable egress filtering globally. The egress-filtering command is accessible from the vnsmode::adminctr context of the CLI.
on | Enables global egress filtering. When egress filtering is enabled globally, it overrides individual wlan settings. |
off | Disables global egress filtering. When egress filtering is disabled globally, it overrides individual wlan settings. |
wlan | Enables egress filtering globally on the wlan. When this is enabled, individual wlan filtering settings override global settings. |
The following example enables filtering on the wlan:
EWC.extremenetworks.com:vnsmode:adminctr# egress-filtering wlan EWC.extremenetworks.com:vnsmode:adminctr# apply EWC.extremenetworks.com:vnsmode:adminctr# show Global Egress Filtering: wlan
