Use this command to enable or disable the ability of the Guest Administrator to set account lifetimes. The set-acct-lifetime command is available from the wlan:<WLAN-service-name>:auth:captiveportal context for guest portal mode only.
| enable | Enables the ability of the Guest Administrator to set account lifetimes. |
| disable | Disables the ability of the Guest Administrator to set account lifetimes. Disabled is the default. |
If this feature is enabled, after the guest administrator logs in, the “Account Lifetime” field will be enabled when updating accounts or adding new guest accounts.
This example enables the ability of the Guest Administrator to set account lifetimes:
EWC.extremenetworks.com:wlans:Lab126-12-GuestP:auth:captiveportal# set-acct-lifetime enable
Print
this page
Email this topic
Feedback
