Use the dls-address command to configure the DLS server address and port. The dls-address command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac and routed topologies. This command is visible only when mode is set to local and dls is set to enable. See mode.
| A.B.C.D | name | Specifies the qualified IPv4 address or name. |
| port 0-65535 | Specifies the DLS port number. This is an optional parameter. The default port is 18433. |
The following example sets the DLS address as 10.10.0.10:
EWC.extremenetworks.com:topology:test:l3:dhcp# mode local EWC.extremenetworks.com:topology:test:l3:dhcp# dls enable EWC.extremenetworks.com:topology:test:l3:dhcp# dls-address 10.10.0.10
Print
                        this page
Email this topic
Feedback
