This section describes commands used to enable and configure a location-based service on a Wireless Appliance and Wireless APs. These commands are located in the lbs context of the CLI. Execute the lbs command at the root level to enter lbs context.
Aeroscout and Ekahau are the currently-supported location-based servers.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the lbs context:
For information on related commands that are available in other contexts, see Related commands.
Print
this page
Email this topic
Feedback
