Use the delete command to delete a bandwidth rate control profile. The delete command is accessible from the vnsmode:rateprofile context of the CLI.
If the rate control profile that you are attempting to delete is being used by any other VNS, the system returns the following message: You can not delete this profile because it is used by other VNS.
| profile_name | Specifies the name of the bandwidth rate control profile to delete. |
The following example deletes the lowspeed profile:
EWC.extremenetworks.com:vnsmode:rateprofile# delete lowspeed
Print
this page
Email this topic
Feedback
