Use the sync command to enable or disable automatic synchronization of this topology across paired controllers. The sync command is available from the topology:<named-topology> context of the CLI for b@ac, b@ap, and routed topologies.
| enable | Enables synchronization. |
| disable | Disables synchronization. |
The following example enables synchronization:
EWC.extremenetworks.com:topology:r1# sync enable
Print
                        this page
Email this topic
Feedback
