Use the psk command to configure a pre-shared key in a dynamic mesh or WDS WLAN service. The psk command is accessible from the wlan:<WLAN-service-name> context of the CLI for a dynamic mesh or WDS WLAN service.
After you run the psk command, run the apply command to implement the changes.
| shared-secret | Specify a pre-shared key for this dynamic mesh or WDS WLAN service with a key length of between 8 and 63 characters |
After this command has been used to configure the pre-shared key for a WLAN service, it will no longer be avaiable.
The following example configures the pre-shared key for the WDS WLAN service wds-test as testsecret:
EWC.extremenetworks.com# wlans EWC.extremenetworks.com:wlans# wds-test EWC.extremenetworks.com:wlans:wds-test# psk testsecret EWC.extremenetworks.com:wlans:wds-test# apply EWC.extremenetworks.com:wlans:wds-test# show Service type: wds Pre-shared Key: testsecret Name: wds-test Enable status: enable Pre-shared Key: testsecret SSID: wdstest EWC.extremenetworks.com:wlans:wds-test#
Print
this page
Email this topic
Feedback
