Use the internal-honeypot command to enable or disable the preventing of any station from using an internal honeypot AP. The internal-honeypot command is accessible from the mitigator:scprof:<named scan profile> context and the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the internal-honeypot command, run the apply command to implement the change.
| enable | Enables prevention of any station from roaming to an internal honeypot AP. |
| disable | Disables prevention of any station from roaming to an internal honeypot AP. |
The following example enables prevention of roaming to internal honeypot APs:
EWC.extremenetworks.com:mitigator:scprof:scp_name# internal-honeypot enable EWC.extremenetworks.com:mitigator:scprof:scp_name# apply
Print
this page
Email this topic
Feedback
