Use the vsa-vns command to include VNS information in the message to the RADIUS server. The vsa-vns command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the vsa-vns command, run the apply command to implement the changes.
| enable | disable | Specifies to enable or disable the inclusion of VNS information in messages to the RADIUS server. |
The vsa-vns command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of VNS information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-vns enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-vns VNS as VSA attribute: enable
Print
this page
Email this topic
Feedback
